Hello everybody, I just changed front rotors and pads on my 89 xjs
and I need some help with the rotor to hub and upper and lower
caliper bolts torque values. Having not worked on the car for at
least a year, I can’t locate my jaguar ‘‘litterature’’, searching the
forum and the book didn’t turn anything up.Please help.
Also, Mintex brand pads came with the brembo rotors. are those pads
a good choice? If not, can you suggest alternatives?
Thanks in advance.–
89 XJS, Conv, Lucas CEI, Keisler Exhaust & 5 speed Mods
Atlanta, GA, United States
Hello:
From the ROM:
Front Disk to Hub: 30-36 lbf. ft.
Caliper to Vertical Link: 50-60 lbf. ft.
Odysseus
'88 US Spec v-12 coupe
Bucks County, Pa, USA
In reply to a message from Odysseus Marcopolus sent Tue 11 Dec 2007:
Thanks Odysseus!
Rotors and pads are on the car, wheels have been rebalanced. No
more shake nor brake pulsating.
Next: high and low pressure power steering hoses damaged during
install of new tower-rack seal (which by the way is still leak-free
after 6 months.)–
