I just got an 84 xjs 93,000 miles. I have always owned American
classics and this is my first Brit. I am looking to learn
everything about keeping one of these. Here are my immediate
concerns
Congratulations.
- The fuel ring split and I had a fire a year ago two days after I
got it. Well $3000 and all parts replaced later, should I be
concerned of another fire?
I’m confused … You just got it, or you’ve had it a year?
The “fuel ring” split? Do you mean the fuel rail? It split? That’s …
Not good. If you have a new fuel rail and all new hoses (including feed and
return lines), there is probably no need to worry about another fire, unless
you are talking about the fuel rail and there’s a remaining reason for it to
have split in the first place; like that it’s over-pressurized.
- What about the transmission? The car is pretty fast but 93,000
miles.
Pretty much bullet-proof. Get a transmission service to be safe (probably
$300 or so) as recommended in another response.
- When I put the key in, it takes a moment or two for the battery
to have enough juice to kick it over, from there it charges back up
to mid level. At the same time, I have to disconnect the battery
each time I stop the car due to a mystery draw when sitting and not
running. I do this over and over and it works but ???
Are you sure you have a drain and not just a dying battery? While a
properly charged battery will last a long time, they don’t last forever. If
a new battery yields the same consequences, your alternator is either not
charging the battery to the levels it should be, or you have to find where
the drain is coming from. There is a lot of information on tracking down
battery drains in the archives, including a fairly recent thread on the
power antenna being a fairly common source.
Anything anyone can help with, I mean basics would be great.
There are people who would say the cooling system recommendation on the
earlier response is a bit excessive, but I wouldn’t say that changing ALL
your fluids on top of that transmission service is a bad call (coolant, oil,
tranny, diff, brake, PS). You can get a pretty good feel for what’s
rumbling around in your cooling system and whether or not you need to start
planning work on it from the condition of what comes out after a good flush.
Have a good look at the steering rack and PS pump, as they seem to be common
failure points by your mileage (and earlier). Plan on replacing anything
rubber in the engine bay at some point
Yes, download “The Book”. It’s a compilation of Kirby’s experiences
maintaining his own car and various discussions on the list, organized
nicely into sections. It’s a good starting point for most issues.
Gordon
'88 XJ-SC (Lucas CEI) Bagheera (47,000 miles)
'95 XJ6 (VP) Kyriell (129,000 miles)
www.myjags.net
Alexandria, VA US
