[xj-s] LUCAS 3ECU trouble
Guy. I reaaly need big advice now.
I thought either the ECU or Power amplifier is dead as when
ignition key turn on, I rotate the throttle and one set of
injectors click( 1,3,5 A and 2,4,6 B). I change the ECU what I got
is similar but this time the other set of injectors click ( 2,4,6A
and 1,3,5 B).
What should I look into?
Ground? EFI main relay?
My 1976 Pre HE v12 reaaly got me this time.
Your help& suggestion would be highly appreciated.
Cheers–
xjs v12
Bangkok, Thailand
injectors click( 1,3,5 A and 2,4,6 B). I change the ECU what I got is
similar but this time the other set of injectors click ( 2,4,6A and
1,3,5 B).
Just a guess, mind you, but I’d check the throttle switch.
– Kirbert
In reply to a message from rzenix sent Fri 26 Jan 2007:
That is normal, as is explained on our website in this
section:-
http://www.jagweb.com/aj6eng/djetronic.php
The switch contacts only initiate injector pulses in the
injector group which is currently active, which will be
random following switch-on without cranking.–
and 1,3,5 B).
Roger Bywater / AJ6 Engineering
and 1,3,5 B).
This is normal. It fires the set that had last fired when
the engine was running.
You can read how this works at the AJ6 Engineering Web site.
Link from mine. See Sources of Jag parts.
Ed Sowell
1976 XJ-S
http://www.efsowell.us/ed/myJag.html
