In reply to a message from Kirbert sent Wed 18 Sep 2013:
Yes, they are the inductive type. Generate their own A/C voltage
without needing magnetic slugs in the flywheel ring gear or the
timing fingers. Just dug up some good info from the link below:
http://www.tiepie-
automotive.com/en/Measurement_examples/Sensors/Crankshaft_Sensor_Ind
uctive
If the link will not copy and work in your browser, just use
Google, or you favorite browser, and type in the following search
string - without the quotes:
‘‘measuring crankshaft rotation speed’’ Look for the Link to TiePie.
Here is some interesting and relative stuff for the inductive type
pickups Jaguar has used to measure the crank position and the rpm
of the flywheel � as well as ABS wheel speed via a reluctor ring
and similar sensor at each wheel, + the speed transducer on the
differential cover:
http://www.tiepie-
uctive
Of note, is the use of the same sensor to compute both rpm and
crankshaft position. To use the same source for crank position,
one needs to knock out one or two teeth. Obviously, this presents
a problem on the flywheel ring gear as the starter would like to
have all the teeth present. I�m guessing that some sort of
reluctor ring is used in the above example, and it has a lot of
teeth inasmuch as the cycles are spaced very close together, or the
scope has a very slow sampling rate. But, the gap in the teeth is
obvious. A higher scope sampling rate would help space those close
order cycles out to where they would have a better shape to
illustrate the plus and minus swings of the A/C pulse. Also, the
information for this example states the starting voltage as low as
+/- 0.25 volts, but the running voltage could be as high as +/- 60
volts. Therefore a lower voltage range can be selected for
checking the waveform while cranking. But, if the engine is going
to run, idle at maybe */- 8 Volts, but at speeds higher than idle,
it could go as high as +/- 60 volts.–
lockheed 92 XJS Cpe/97 LT1 Miami FL/ 96 XJS Cv 4.0 Austin TX
Austin, TX, United States
