The worst engine I ever rebuilt was a Chevrolet 350
which had run on Pennzoil since the day it was new. It
was totally sludged up and the filthiest mess
imaginable. Later , while working in a dealership we
took a Monte Carlo in which was a Quaker State user,
and it wouldn’t drain. We ultimately flushed it with
Diesel fuel to clean the pan out. I personally
wouldn’t use either of those brands to hold dust down
in my driveway.
Pure synthetic oil does not work well in engines which
use heavily leaded fuel, such as piston engined
aircraft as the base does not hold lead salts in
suspension and it precipitates out in the form of a
gray goo known in the industry as “Gray Paint” In an
engine which does not use leaded fuel, such as jets
and any automobile built in the last couple of decades
it’s hard to beat. The chief advantage of synthetic
oils is there longer lifetime. Contrary to what used
to be stated as fact, oil does wear out. Under the
scanning electron microscope it was determined that
the long hydrocarbon chains which make up lubrication
oil are “chopped up” in the course of performing their
duty. The synthetics can be built up with much longer
chains which take longer to break down. The semi
synthetic has proven to be an excellent alternative in
the aviation industry. If one is going to adhere to a
fairly short change interval such as 5000 miles, I
personally can see no real advantage to the full
synthetic over the semi. If the decision is made to
use the full capability of the synthetic oil it would
probably be necessary to run the oil for 10000 or more
miles, but that is more than most of drive our cars in
a year, which ushers in a host of new problems such as
acid build-up in the oil. I personally run Valvoline
semi-synthetic in the Jaguar and Aeroshell 15w50 in
the plane.
Tom Wilson=====
Everybody knows the boat is leaking…Everybody knows the captain lied
Do You Yahoo!?
Yahoo! Health - Feel better, live better
