Can someone tell me if the sound that you listen for when
shorting out the valet switch wires, to put the unit in
‘learn’ mode, comes from the unit in the boot/trunk or from
somewhere else ie in the cabin or from the alarm sounder
under the bonnet/hood? What should you listen for and from
where? Many thanks. Richard–
Richard Ashley. 95 XJS Celebration. 4.0 Ltr Coupe
Scarborough, United Kingdom
In reply to a message from Jackdog1 sent Fri 23 Nov 2012:
The sounder is in the front left wheel well behind the headlight.
It will emit the sounds as heard on Mark Janzic’s U-Tube video.–
lockheed 92 XJS Cpe/97 LT1 Miami FL/ 96 XJS Cv 4.0 Austin TX
Austin, TX, United States
In reply to a message from lockheed sent Fri 23 Nov 2012:
Thanks. Is it the same sounder that makes the noise if the
car is broken into and also chirps when the remote fob is
used to set the security system along with the lights
flashing? Many thanks. Richard–
‘‘Is it the same sounder that makes the noise if the
flashing?’’
In reply to a message from lockheed sent Sat 24 Nov 2012:
Richard,
Did it work for you? I tried programming my '95 for 2 months,
studying and trying out different methods, but finally wound up
paying the dealer to do it with their ‘‘box’’. Just wondered if you
had luck…
In reply to a message from CJ95 sent Mon 26 Nov 2012:
Hi John.
The box of tricks is still with the auto electrician so not
tried yet but will let you know if I have any luck. Cheers
Richard–
had luck…
