Simple question…the thermostat is it in the upper hose
on left front side of engine…?
Thanks–
ivan segal
Thanks–
ivan segal
In reply to a message from sloth sent Wed 31 Aug 2016:
ONE of them is in the housing on the engine side of that
hose. The OTHER thermostat is in the housing on the engine
side of the upper hose coming from the right side of the
radiator.–
David Christensen, Tucson, 13 XJ, 91 XJS Conv, 65 Etype OTS
In reply to a message from davchr sent Wed 31 Aug 2016:
Hi:
Thanks davchr your info is about what I thought…
I will check both thermo. before I elect to remove radiator…
Note: I rebuilt the entire rear-end rotors, pads et all…on
my back in my garage…(no big deal)
Sloth–
ivan segal
Ivan,
Make sure you test both in boiling water at the same time,
also have a pot of ice water so you can drop the two stats
into it at the same time. Both should be ‘‘double action’’
stats that have the blocking plate also. They close the
bypass off when the stats open to make all the water go to
the radiator.
If they check good also make sure you put them back in
with the air vents at the twelve o’'clock position so they
vent air. Most books do not stress the need for these
special stats.–
DanS
columbus ga. usa, United States
6 or 12 cylinder?–
stephen davis 1976 XJ-S, 1989 XJR-S, Sl SWB XJ12 x 3
gorae, Australia
