This pertains to the 89 XJ-S (W=White), 5.31 Lucas
After a trip to Tampa, FL from NY (smooth trip) I took the
auto in for some maintenance. While there one of the person
working there took it upon himself to wash the engine (very
clean now, not a spot of grime and or grease). First he
applied degreaser then preassure wash it (No it was not
me!). After this they proceeded to air dry it (using air
hoses), then just let it sit under heavy lamps.
When I went to start the auto; it caught a bit, chooked a
bit, and it sounded as it wanted to turn off (never done
this), but after a while it ran ok. For a few minutes white
smoke came from the tail pipes. I was told that this was
ok, the engines was just getting rid of moisture. For a
while the auto made a (pop, pop, pop) out of the LH tail
pipe. This was fixed (today) by re-connecting two Fuel
Injectors wires that had come loose. Ran the auto, for a
while and everything seem to be ok.
Took the auto for a short trip, and about 10 minitues into
the trip, I noticed that the ‘‘Coolant Temperature Gauge’’ had
gone to the ‘‘H’’ position. Parked auto, and let it cool
down. Heading back to the house had to make about three (3)
stops, to let auto cool down.
In addition I noticed that the ‘‘Electric Raditor Fan’’ is not
comming on, when that ‘‘Temp Gauge’’ gets close to the ‘‘N’’
position. It does not come on after it passes it.
Determined this after bringing auto back, and let it run on
drive way.
1 - The auto has no coolant leaks, has plenty of coolant,
The Stat’s seem to be working fine.
2 - I have checked the ‘‘Coolant Temperature Gauge Sender’’
and it seem to be working fine.
3 - I have checked the ‘‘Electric Radiator Fan Relay’’ and
that seems to be fine. At least I beleive I got the right
relay. It was not a Lucas relay, but a Hella relay. The
‘‘Book’’ part # 4RD 003 520-13, but mines says 4RA 003 510-33.
This came from a Red Socket on the LH engine compartment.
The only other Red Socket I can find is under dash in the RH
side.
4 - Connected the fan, (temp connection) and is working.
Right now I’m at a lost as what to do next.
Should I dismantel the entire engine coolant system?
Any and all assistance would be greatly appreciated…
Thank you,
J.R.–
1989 XJ-S (W), 5.31 Lucas 1989 XJ-S ® Converting
new orleans, la / for now / ny, United States
