hi, sorry for speeling errors english is my third language
I am replacing the rear wheel bearings on my 1995 xjs 4 litre last
six digit of vin number is 199880
i think I have the wrong hub carrier on my rear suspenssion
the shop manual calls for part number mhf3291aa for cars with
serial number begining from 198335
however what is instaled on my car is part number ccc5701
wold anyone confirm that my discovery is a fact or not
i know mhf3291aa could be used as subsitute for ccc5701
however I am not sure if ccc5701 could be used as substitute for
mhf3291aa–
user523
In reply to a message from user523 sent Thu 6 Aug 2009:
If it is the original hub carrier on your car I wouldn’t worry
about it. Does it look like it’s been changed?–
Roger’95
In reply to a message from Roger’95 sent Thu 6 Aug 2009:
hi , I have purchased the car recently so I do not know if it is
the original hub carrier or not it may have been replaced as the
car has 320000 miles ( not 32000) and I assume there has been a lot
of work done on the car and some of them not perectly done.
for example they used a 10 mm bolt with wrong thread to replace the
original brake caliper bolt which I found out when I was replacing
the wheel bearings however I was lucky that the bolt material was
softer than the on where caliper bolts screws in which resulted in
the bolt threds going bad
thanks for the reply–
