In reply to a message from lockheed sent Sat 6 Aug 2011:
The antenna worked when I got the car…it died after a while, and I
replaced it with one from my parts car. That one worked for a
while, then it too quit. There is something wrong with the relay I
think. Looking at the plug from the radio side, white is top left,
blue is top right, black is left middle, yellow is bottom left, and
red is bottom right. Red has power always, yellow has power in
accy and on key positions. Blue has power with the lights on. I
have connected yellow to white, and everything seems to work,
except the antenna. I have pretty much given up on having a power
antenna, I will just purchase a collapsable one. I can’t use a one
piece because of the TWR deck spoiler, which the antenna goes
through.
The radio worked fine, until I started trying to hook up an
aftermarket antenna, just by trial and error. I did something
wrong, blew the 20 amp antenna fuse, and then had no radio at all.
Replacing the antenna fuse didn’t bring back the radio, but the
fuses for both the radio and the memory circuits didn’t blow. Its
possible that I shorted something out inside the radio, trying to
connect the antenna. Regardless, its now working. One question
though…with the radio turned off, I still get the station display
on the radio. It goes off with the key off. I can’t remember if
this is normal. I haven’t driven this car since last year, and I’m
trying to bring it back to life so I can sell it.
I spent most of 2 days just getting the gauges and warning lights
to work. I have all of the warning lights working, with the
exception of the rear defroster light. It was working, then quit. I
cleaned the corrosion off the socket, replaced the bulb, still
nothing, no power to the printed circuit board. I really don’t
care, because all of the important lights are working.–
guarantee the the wiring has not been fiddiled with by one of the
previous owners or some short cutting mechanic? Confirm which wire
has battery power at all times, and which wire has 12V power only
when the switch is in accy (2), run (3), and the last wire is
Bill 87 TWR XJS Ontario, Canada
