By the same token, you could rent a proper spring compressor for $5 or $10.
I bought a pair of spring compressors (ostensibly for MacPherson Strut
springs, but they worked fine for XJS rear shock replacement) for less than
$30.
For about $5 and about 15 minutes with a welder, you can build your own. I
would venture, better than some of the cheaper units I have seen. I trust
mine a lot more than I would a rented pair.
Paul Bachman
You don’t know how much is enough, until you know how much is too much----------
To: xj-s@jag-lovers.org
Subject: [xj-s] Re: BALL JOINTS -safety
Date: Friday, January 09, 1998 3:22 PMBy the same token, you could rent a proper spring compressor for $5 or
$10.
than
$30.
