I want to remove the motorized antenna from the trunk be ause it
doesnt opperate correctly anyway so I want to replace witha fixed
antenna. Question is is that if I do that do I have to rewire the
antenna cable that goes to the radio or can I use the existing
one?–
dantheman199
In reply to a message from dantheman199 sent Fri 22 Jun 2012:
You can use the existing one. But, why not keep it classy and
replace the factory one with an aftermarket Harada (MX22?)? Or, a
Hirschman antennna? Both reasonably priced, and readily
available. I don’t remember the model nos’, but it you do a search
of the XJS archives, you will find information there.
Arhive: XJS
Date: all
keywords: Search first using ‘‘Harada’’, do second search
using ‘‘Hirschman’’. No need to use a poster’s name.
I used a Harada in our '89 - it worked perfectly, and never had a
problem with it.–
lockheed 92 XJS Cpe/97 LT1 Miami FL/ 96 XJS Cv 4.0 Austin TX
Austin, TX, United States
Hirschmann also makes a rebuild kit for the original antenna and
well worth the effort if you want to keep the cat original.–
MT Time
Sorry, don’t have the part sheet any longer in my file and don’t
exactly recall all the parts included in the kit but all of the
gear wheels, pins, etc. Don’t remember if it had a replacemnt
circuit board. I had lost a pin when installing a new mast as I
had to take the antenna apart to remove a broken piece of the gear
cable that was still lodged inside. In the process I dropped a
tiny gear securing pin. Contacted Hirschmann and they sent me
sheet relating to this rebuild kit. I think it was about $35 but
might have been more. Anyway, I ended up making a replacement for
the pin I lost so didn’t order the kit. Suggest contacting
Hirschmann, directly. That is what I did at the time and they were
very helpful.–
MT Time
In reply to a message from George Balthrop sent Fri 22 Jun 2012:
speaking of antenna’s I finally got my radio working on the
weekend. I actually got the code from the dealer.
It sounds like a really cheap radio.
anyway as soon as I turn the radio on is the antenna supposed to
raise automatically.
How can you tell if it’s shot or whether it just needs lubrication?–
the mast which is easily available) is the circuit board.
What is included in any ‘‘rebuild kit’’ of which you are aware,
In reply to a message from Jagrr88 sent Mon 25 Jun 2012:
just go to ebay and get the hirshmann
generic -i think they are 50
amd come with a bunch of top adapters.
i just did mine and it works great
JUST NO DELAY -who needs that
works as soon as you turn on radio–
aearch
