I have checked the archives and ‘‘The Book’’ and di find some tips
for the skislope removal.
I have removed the screw under the armrest/storabe box. I loosened
the screws holding the side tabs. I unsnapped all the switches.
My problem is I cannot budge the gear selector housing. I assume
that after removing the shifter knob the assembley will slide over
the selector lever. Are their locations on the housing I need to
unscrew or unsnap?
Ron Santmyers
88 Hess & Eisenhardt–
Ron Sant
The gear selector assy with black side and top showing
shift pattern stays in place. The skislope should
come out. You can remove the ashtrays to see and get
a better grip. Carefull with the lower ashtray
bracket screws or you will be removing the console to
find some tips
box. I loosened
the switches.
housing. I assume
will slide over
housing I need to
unscrew or unsnap?
the selector lever.
The selector housing stays with the console cover (ski slope).
unscrew or unsnap?
I lied! What I should have said is the console cover comes up,
leaving the selector housing behind. The selector housing is
attached to the body. At least that’s the way it is on the early
XJ-S.
In reply to a message from Ron Sant sent Thu 24 Aug 2006:
I just refitted my skislope (88 model). There is only the one or
two screws at the back under the cover of the centre cubby hole
clip, and the two nuts accessed through the lighter and speed
control switch cutouts. The skislope has two tabs at the front that
engage in the aircon construction, just under the radio surround,
so you must lift it out at the back. That is it. It slides over the
gearbox selector housing. Check if yours is not caught at a corner
at the back where those one or two screws came out. (I’m reasonably
sure it is just one screw, but whatever how much, it is very
visible.
Regards,–
Will it become obvious how to remove the selector housing after I
pull it?
In reply to a message from Martin D sent Thu 24 Aug 2006:
Thanks to all responders!!
The right rear corner next to the storage compartment/armrest was
really stuck. I finally pried it off and the slope slid off nicely.
I had another slope ready to install. The install went well, with
the exception of breaking a tab on the cruise control switch. I
will replace it. Also the replacement of the ash trays was a little
dicey, but that is finished.
I think I will go back in the garage to look at it again!
