Make some notes in your Kirby book if you want to
clarify for yourself the section on removing the rear
subframe. Kirby states…
“The basic idea is to put the rear of the car on
jackstands, position a floor jack under the center of
the IRS, unbolt it from the car, lower it and roll it
out from under the car. The first challenge: You need
to get the rear of the car high enough to get the
suspension out from underneath. To get it out the
rear of the car, the lowest point of the bottom of the
trunk needs to be higher than the height of your floor
jack when fully collapsed plus 13�. Plus an inch for
fudge, just to make sure.”
And then it goes on about other problems with lifting
the car so high in the air.
That requires HUGE jackstands and requires lifting the
car probably higher than many of us are used to.
The rear of the car doesn’t need to go this high
because you are not removing the rear end backwards
under the trunk… you should be removing it sideways
out one of the wheel arches. In theory, with the
wheels off, the car doesn’t need to be much higher off
the ground than it is when you drive it.
–John__________________________________
Do you Yahoo!?
Take Yahoo! Mail with you! Get it on your mobile phone.
http://mobile.yahoo.com/maildemo
