[xj-s] Socket size for lug nuts AND front crank pulley nut?
Hello,
I am buying some impact sockets this weekend and want to be
certain the set has the proper sizes I am going to need for wheel
lugs, brake caliper/rotor and front crank pulley nut. Any ideas?
Thanks,
Thomas–
1986 XJS
You might wanna buy the front crank pulley socket separately. It’s a
great big thing. Buying a set that includes it would probably be a
great big set, intended for truck work or whatnot, and big bucks.
Better to buy a regular size set plus one big socket for that crank
pulley nut.
BTW, I don’t even own an impact set. I just use my normal sockets
with my impact wrench. I know there’s a risk of cracking them since
they are harder than impact sockets, but I haven’t broken one yet.
And if I did, they’ve got a lifetime warranty!
– Kirbert
In reply to a message from Got V12 sent Fri 5 Jun 2009:
can’t you take a normal set of sockets and try them until
one fits? The crank nut might be hard, but the wheels are easy.–
GarethThomas
In reply to a message from Kirbert sent Fri 5 Jun 2009:
I do have a basic set of impact sockets. I fiond that they are six
sided and good for stubborn bolts that take lots of toque to break
loose, one way or another by impact or by a big cheater bar. They
are not as likely to round off the heads of the stubborn ones.
I have an electric and an air impact. I like them a lot.
Some time ago, I had to drive some good size lags to secure a post
and the weatherhead on the house. The electric one drove those big
lags right on in, no sweat.
And many years ago, the kid that did our lawn had a flat on his
tired Toyota pickup. He couldn’t get the spare loose. It is a
terrible mount under the bed. Whirrr, gone. The wheel lugs were
also apparently, gorilla installed. The electric couldn’t hand;le
them, but the air made short work. I introduced him to a torque
wrench and anti-seize. Good kid. Hard worker. I taught him as much
as I could about s lot of things.
Carl–
Carl Hutchins 1983 Jaguar XJ6 with LT1 and 1994 Jeep Grand
Walnut Creek, California, United States
In reply to a message from cadjag sent Fri 5 Jun 2009:
Thanks for all of the information!
Thomas–
1986 XJS
In reply to a message from Got V12 sent Sat 6 Jun 2009:
No one said what size the crankshaft damper nut is, I’d like
to know as well if someone knows.
Thanks
Ian Irving
Riv944
1990 V12 convertible.–
Thomas
riv944
Hi Ian,
The crankshaft damper bolt is 1-5/16" or ~ 33mm. If you will indicate
where you are located, perhaps someone can help you locate a supplier
for a rebuilt damper for your 90 V12 Before assuming the damper is the
cause of the “screech,” you should put a line of white paint on the
damper from front to rear, and see if that misaligns after a screech.
85 & 89 XJ-S Coupes; 89 XJ40 VDP-----Original Message-----
Thanks
In reply to a message from George Balthrop sent Tue 9 Jun 2009:
Hi George
Thanks for the info. I have done the paint job and it is the
damper causing the noise. Where I am is complicated, I’m in
France but my car is in Vanuatu, neear Fiji. I’ll be back
there later in the year, via a short stay in New York and
then San Francisco so I could pick up the part in either
place. Failing that, I’d mail order it to be sent to a
friend in AZ who would send it to me at some stage.
Ian Irving–
The crankshaft damper bolt is 1-5/16’’ or ~ 33mm. If you will indicate
cause of the ‘‘screech,’’ you should put a line of white paint on the
riv944
