In reply to a message from mike90 sent Tue 26 Nov 2013:
Gene:
One last thing: if those cage mounts have never been changed, they
likely need to be changed. Look 'em over. Age (if not miles) mean
those rubber bits get brittle.
And: if you choose to do this work with the cage still in the car:
BE SURE YOU SUPPORT THE CAGE! There is relatively little holding
that assembly up there, really. It comes down to the rubber in the
mounts and the trailing arm bushes, and then the little bits of
cable and tubing hither and yon. Not much for an assembly that
weighs more than I care to contemplate.
I would not want to be under the cage when the car is in the air
and that cage is unsupported. The corollary: I do not lift the car
from the rear without supporting the cage.
If you already know all that, well, my apologies for the
redundancy. I just don’t want to later hear about a guy who was
injured by the rear cage coming down.
-M–
Mike, 1990 5.3 XJS Conv., 5-speed, SE-ECU, TT Extractors
Lakewood, OH, United States
