[xj-s] Strange Aux Fan Behavior
When I turned the key yesterday, the auxiliary fan came on immediately;
before the engine even started. “How strange” I thought, and took a look.
One of the wires has a nick in the insulation, but I couldn’t mind anything
otherwise off.
I was in a hurry and decided “oh well, screw it - it’s really cold today so
if worse comes to worse, I’ll just unplug it”. Driving around through the
day and night, I experienced nice running temps. She performs great when
cool like that. The fan seemed to operate properly, though kicked in at
lower temps than normal from time to time.
Stuck/sticking thermostat somewhere?
Gordon
'88 XJ-SC (Lucas CEI) Bagheera (46,000 miles)
'95 XJ6 (VP) Kyriell (128,000 miles)
www.myjags.net
Alexandria, VA US
This happens every so often on my car, too.
My car and I imagine yours as well is wired so the fan comes on with the A/C
compressor. If the engine was shut down with the compressor engaged then
it’ll be engaged when the engine is restarted…until the climate control
readjusts.
Doug Dwyer
Longview, Washington USA
anything
otherwise off.
// please trim quoted text to context onlyFrom: “Gordon Vivace” gordon@myjags.net
on with the A/C compressor. If the engine was shut down with
the compressor engaged then it’ll be engaged when the engine
is restarted…until the climate control readjusts.
AHA! And that’s exactly what happened because I noticed immediately that
the heater was on and I thought “that’s strange … I always turn that off”.
Except … The engine wasn’t started. I always turn the key to “on” for a
couple seconds before cranking it and the fan came on then. Same thing?
Gordon
www.myjags.net
Alexandria, VA US
Gordon,
Could be the fan thermal switch… mounted in the water pump inlet housing.
Ed Sowell
76 Xj-S
mind anything
otherwise off.
cold today so
Gordon
I’m thinking the fan temp switch.
Jamie & Dru - Everett, WA
88 Series III V12 VdP - Roxanne
89 XJS V12 Convertible - Butch
Jaguar Owner’s North American Tour - http://jonat.org
April 15, 2004 - July 4, 2004
.----- Original Message -----
Sent: Monday, November 10, 2003 5:57 AM
Gordon
www.myjags.net
Alexandria, VA US
Well, I’ll be darned! It’s amazing how much you can learn on these Lists.
The A/C link makes total sense, I just didn’t even think of that. I’ll keep
it in mind from now on though.
Good show Doug!
off”.
Gordon
www.myjags.net
Alexandria, VA US
// please trim quoted text to context only----- Original Message -----
Sent: Monday, November 10, 2003 7:03 AM
A few more possibilities:
How about a stuck relay? Or a short in the temp switch wiring? Or…
Don’t these era models have some kind of a diode device that is supposed to
keep the aux fan circuit alive after shutdown? If so, can’t a faulty one
cause the fan circuit to be hot when the ignition is switched on?
Gary
94 4.0L Convertible
San Jose, CA----- Original Message -----
