Replaced the coil in my 94 today. The engine now runs great. To
refresh everyone’s memory, I had thought it was the fuel pump since
the problem ended at 2500 rpm. But the dead A bank confused me and
I never had a coil work only at higher rpm. Will replace the other
coil prophylactically.
But as soon as I started it, the check engine light and FF19 came
up. Could this be related or a seperate problem altogether? Any
suggestions where to start?–
Maynard 94 XJS V12 Coupe 91XJS(RIP) 86XJ6 78MGB 67MGB
Niles, IL, United States
FF19 is fuel metering above idle. Your coil problem
could cause this problem. Clear the code and drive
the car to see if it comes back.
Check the response of the O2 sensor.
Intake leak
Purge valve
runs great. To
fuel pump since
confused me and
replace the other
and FF19 came
altogether? Any
In reply to a message from Maynard sent Wed 22 Mar 2006:
Did you have the battery undone when you changed the coil? You
should have. If not this may (as previously said) have set your
code. Undo the negative battery post for 5 minutes then try it
again.–
Rob Wade
Windsor Ontario, Canada
Kirbert
4
code.
Why? The coil is not powered when the ignition is off.
In reply to a message from Kirbert sent Tue 28 Mar 2006:
It is common (and good) practice to undo the battery any time you
are undoing an electrical connection or sensor on a computer
controlled vehicle.–
Rob Wade
Don’t think that disconnecting the battery would have done anything
to prevent thelight from coming on since the coil is only hot with
the ignition on.
Disconnected the battery and the code disappeared.–
