Gentlemen:
First, apologies for the long post. Been a very frustrating
experience, so I hope someone can provide some clues.
OK, the facelift XJS cars came with the Sanden 709 A/C
compressor. Both V12 and I6.
Jaguar part numbers were initially CBC6522 and CCC6592,
changed later to MHE7300aa and MHE7300ba, respectively.
The part # change must have been dictated by the R12 to
R134a changeover with VIN1905028. The part numbers can be
found cross-listed to numbers from a variety of vendors,
including Four Seasons, GPD, Bosch, etc. and this is where
the mess begins.
The I6 owners are probably lucky that can get a direct fit
SD709 from pretty much everywhere (ca. $200), including the
local AutoZone, but if you are a V12 owner, only a few
places offer the correct OEM compressor at a cost of $1000+.
ALL aftermarket versions are incorrectly listed, ask me how
I know.
Many hours on the internet seem to converge on the
following:
I6: Jaguar part MHE7300aa = FS78589 = SD7H15-7895
V12: Jaguar part MHE7300ba = FS58739 = SD7H15-7743
On top of that, the correct XJS part# is incorrectly shown
on the JDHT catalog ā it shows a pulley using a serpentine
belt with 6 grooves ā pulleys for both MHE7300aa and
MHE7300ba are 132 mm and use a V-belt.
Another Jaguar atrocity ā apparently there is another part
number MHC7300aa, which must be equivalent to MHE7300ba
(different pulley), judging from some pictures I found, but
it does not come up searching the MY, and that is a whole
different story.
The questions.
Having seen ads for the whole compressor (brand new, no
core) for $200, I presumed this route will be cheaper
alternative to shaft seal/bearing replacement on the old
unit. As outlined above, it turned out it wonāt be that
simple.
This page shows the compressor I have fitted in my car:
Same site says that the 6L V12 uses this compressor:
Can someone else with a facelift V12 confirm that the
factory A/C compressor is the former and not the latter,
despite the catalogās suggestion.
I6 owners should have this one:
http://www.findpart.org/part/ast-mhe7300aa/
To me, MHE7300aa and MHE7300ba appear to identical in every
ways except the mounting bolts. Fabrication of an adaptor to
fit the readily available MHE7300aa in the āveeā of the V12
will be beyond my abilities.
Looking up some other Sanden compressors, I found this one:
It is from Volvo and the dimensions appear to be a very
close match. Will this compressor fit my car (after a
pulley/clutch swap)?
All dimensions are almost identical, the only potential red-
flag is the Sanden model number (SD7V16). The Jaguar one is
SD7H15.
Again, I am sorry for the long post. The documentation in
āThe Bookā of the A-6 compressor used by Jaguar and the
generic versions is excellent, no such luck with the Sanden.
Hope this will help many facelift owners (when/if properly
resolved).
Best regards,
Steveā
'95 XJS convertible - V12 6.0L
āPosted using Jag-lovers JagFORUM [forums.jag-lovers.org]ā
