The second hand interfaces go for around $80 AUD, since I’m not 100%
convinced it is the interface unit yet, I don’t want to spend the money yet,
especially as I could replace all the components on the board for about
$10… I also need to find out whether the Australian interface is the same
as the UK interface.
I assume US gallons are smaller than Imperial Gallons (Why do you Yanks
alway have to be different from the rest of the world) so for my trip
computer telling me I’m using 80+ Gallons would make it over 100 US Gallons
per hour which is not possible. The TC has a metric/imperial switch and to
measure gallon, I had it in imperial mode.
I will disconnect the wire between the interface unit and the ECU and try it
again. Should it read the maximum fuel output or should it read nothing at
all. If it reads maximum fuel output, the interface is working properly and
the fault must lie within the ECU, or the connection between the ECU and the
interface unit.
If the fault is in the ECU, I will not even bother fixing it, as the ECU
works fine as far as the engine goes and gives good fuel consumption (better
than most on the list) and I don’t want to upset it.
Iain Burgess
85 XJ-S UK Spec
Brisbane Australia-----Original Message-----
Sent: Friday, 24 August 2001 13:31
To: Iain Burgess
Subject: RE: [xj-s] Trip Computer
At 07:52 AM 08/24/2001 +1000, you wrote:
I tested the trip computer as you recommended - With the ignition on but
not
started, I get 1.4 Gallons in 1 minute reading which is around 84 Gal/hour.
Driving all the way home, I got 24.5G in 17 minutes which gives me
86.7Gal/Hour (the 17 minutes is not exact).
Had you disconnected the wire between the ECU and the interface unit?
I will re-check the wiring between the ECU and the sender unit, but it
looks
like I have a lot more “theoretical fuel” usage than the 18.5 Gal/hour.
Would mine being a UK spec car make that much difference.
It should have been higher than my XJ6 readings. The data numbers say full
duty cycle flow of 6 XJ6 injectors is 20.5 gallons per hour and 12 XJS
injectors is 34.5 gallons per hour. Those are US measures.
I am not familiar with UK spec equipment so I have a couple of
questions…and my cat isn’t here right now.
Is the interface unit the original? What is normal function of your
computer? Do you have a switch which allows metric display? Could you be
measuring liters?
The ECU is obviously not giving out a continuos duty cycle to the
injectors,
so I am back to suspecting the sender unit.
Sounds like you are on the trail of it. The sending unit seems to me to be
the culprit.
Does the square wave frequency get faster with more fuel used or slower, if
I am using maximum fuel, would it be that the square wave is just
continually “on” thus fooling the Trip computer into thinking it is
infinitely high frequency hence lots fuel being used. If that is the case,
which one of the components in the sender unit is likely to produce this
effect?
The “base” frequency we found was the maximum frequency the interface would
produce with a constant voltage input. The injector pulses provide
interrupted voltage. Thus the constant voltage generates the maximum
frequency the interface produces…Or alternatively stated the full duty
cycle frequency. Thus if the interface is sending a signal with a high
frequency it will as you speculate fool the trip computer into incrementing
more fuel units.
The information I have says each 5.3 injector delivers 18.96 lbs/hr of fuel
at 300KPal. When corrected for Jag fuel pressure of 36 PSI they should
deliver 17.25 Lbs/hr. I don’t have the conversion to imperial gallons
handy but you should be able to grab it. Convert lbs/hr to gallons
per hour then multiply by 12 to get an estimate of the fuel measurement
you are looking for.
My guess is the problem is in the interface rather than the trip
computer. I would be looking there.
By the way interface units are not that expensive here. Have you checked
the price in your end of the world?
Wes
This email and any files transmitted with it are confidential and
intended for use by the Addressee only. The confidential nature
of the information contained in the email and/or file is not waived,
lost or destroyed if it is sent in error to other than the Addressee.
Use or dissemination of the information contained in the email
and/or files by a recipient other than the Addressee may cause
commercial damage to both/either the Sender and/or Addressee.
If you are not the Addressee of this email/files please immediately
contact the Sender and delete this email/files.
