At 09:40 2012-12-21, Kirbert was heard to say:
I have the time on:
- my wrist
- my phone
- my car radio
GPS, which is a highly accurrate time source.
I trust the watch on my wrist. Solar powered (no, doesn’t only work
during the day - it recharges the batteries), and daily, it resets
the clock from NIST radio signals.
The profusion of little indicator lights gets old, too. I now have a
Blu-Ray player in my house with a red indicator light that tells you
when it’s OFF.
In all fairness, it’s telling you that it is in STANDBY - able to
respond to a remote command to start doing things. If it was truely
off, you’d have to get up and turn it on manually.
The tiny LED in the volume dial on our surround amplifier went duff a
while back, and I ended up putting a sliver of white adhesive label
onto the dial to indicate position, as from across the room, the LED
told you where the volume was (this unit doesn’t display volume
percentage on the display).
Push the button to turn it on and the red light
disappears so you can watch TV without staring at a red light.
Suggestion: don’t put your player in the middle of the spot where
your teevee should be. I put my teevee there.
As for useless LEDs, I’ve got you beat. I have a couple of LED
flashlights - a headband one, and a small cylinder type. They work
great, no complaints there. However, both of them (from the same
mfr, and IIRC, came as a pair in one package), have an led that
flashes continuously, perhaps every couple of seconds WHILE THE
LIGHTS ARE OFF to - get this - show that the batteries are
good. This of course eats up the batteries in a hurry.
I end up opening up the endcap so the batteries don’t make contact,
and then when I need to use them, close the thing up and go.
— '88 Jaguar XJ-SC 5.3L V12 (LHD) ‘Black Cat’
Sean Straw '85 Jaguar XJ-S 5.3L V12 (LHD) ‘Bad Kitty’
Sonoma County, California '91 Jaguar XJ40 4.0L (LHD) ‘Trevor’
http://jaguar.professional.org/ '69 Buick GranSport 455 V8
// please trim quoted text to context only>On 21 Dec 2012 at 6:46, Veekay wrote:
