my '86 xjs recently has issues with all turning signals not working
one day and then working again on another.
is there a relay somewhere or a central control unit somewhere?
any help appreciated.–
spanner
miami, florida, United States
In reply to a message from stepspan sent Thu 14 Nov 2013:
It is the relay…–
87’ VDP (black), 86’ XJ-SC (grey), 88’ XJS sport convert
Fort Lauderdale, United States
Hi. Mine are similar but instead of working one
day and not the next they work, then half a
second later they dont, another half second they
do then they dont then they do!! It goes on like
that until I switch them off!!! Cheers Richard.–
1990 Series III V12 Vanden Plas
1990 XJ-S Classic Collection convertible
1987 XJ6 Vanden Plas
1984 XJ6 Vanden Plas
1969 E-Type FHC
1957 MK VIII Saloon
Ramona, CA
P.M.Novak7@gmail.com-----Original Message-----
From: owner-xj-s@jag-lovers.org [mailto:owner-xj-s@jag-lovers.org] On Behalf
Of stepspan
Sent: Thursday, November 14, 2013 6:30 AM
To: xj-s@jag-lovers.org
Subject: Re: [xj-s] turning signal work one day and don’t another
In reply to a message from Big Squatt sent Thu 14 Nov 2013:
any info where it is located?
thanks.
spanner
Kirbert
7
one day and then working again on another. is there a relay somewhere
There is certainly something flaky in that circuit somewhere. On my
'83, when I had the cruise control on, I could turn on a turn signal
and the car would surge forward briefly before settling back to the
set speed. Did that as long as I owned the car. Barely noticeable
in OEM configuration, but after I had the AJ Engineering Super
Enhanced mod done to the ECU it became VERY noticeable, the car would
LEAP forward for a half second when the turn signal was engaged!
Just exactly what the turn signal circuit has to do with the cruise
control, I dunno, and I was never able to figure out how to fix that.
In all likelihood it was a corroded connection somewhere, and it’s
possibly the SAME corroded connection that’s causing your maladies!
There are some here suggesting a relay, or perhaps the flasher unit
itself, but on a Jaguar there’s every possibility the problem is just
some connection somewhere. And replacing a relay or a flasher unit
might just fix it, because you have to disconnect and reconnect in
the process!
– Kirbert
// please trim quoted text to context onlyOn 14 Nov 2013 at 5:22, stepspan wrote:
In another email I gave you a link to the electrical Holy Grail for your
car. Log onto Captain Jaguar website, download the S57 Electrical Guide
for your year and model, and you will have the location with easy to
understand drawings. The S57 will be useful for this problem, and many
more that you may have in the future. I believe it is best to give you the
location of where you can obtain for free an official Jaguar OEM document
with lots of valuable information. Check my earlier email.
Paul M. Novak
1969 E-Type FHC
1957 MK VIII Saloon
Ramona, CA
Of stepspan
Sent: Thursday, November 14, 2013 4:58 PM
In reply to a message from Kirbert sent Thu 14 Nov 2013:
In reply to a message from Paul M. Novak sent Thu 14 Nov 2013:
thank you paul.
i have downloaded the .pdf file for my vehicle model and found
the description on how to ‘locate and replace’ the ‘flasher unit’ on
page 86-36.
i will do this today and follow up if this fixed my problem
permanently.
thank you for sharing this resource.
