[xj-s] which oil power steering?
Which oil should I use for the power steering ? The same red oil
(ATF) as the tranny ?
I checked and it was empty !! Do I have a major problem ?
I am new, working on it for three weeks. Tranny is leaking and not
working (5-speed in mind). Never had the chance to drive the car,
so I don’t know if the steering is working properly.
So I would like to start pouring oil in it.
Dirk–
DirkHaverals Jaguar XJS V 12 1983
In reply to a message from DirkHaverals sent Thu 20 Dec 2007:
Use power steering fluid.–
Rob Wade
Windsor Ontario, Canada
Better yet, use Lucas Power Steering fluid–
BCTCBOSS
Hi Dirk,
 I believe that my owner's manual calls for ATF to be used in
mine. Not to say power steering fluid wouldn’t work, just that ATF
is recommended in mine. But my power steering unit is made by ZF,
so that could be different than yours.
Matt
'95 VDP–
Dirk
Trilithon
In reply to a message from BCTCBOSS sent Fri 21 Dec 2007:
Seconded!
Chris–
whoosh! 1982 XJ-S HE,1998 XJ8L,1983 XJ-S HE(parts)
San Francisco Bay Area, CA, United States
In reply to a message from whoosh! sent Fri 21 Dec 2007:
My manual states automatic transmission fluid, and the stuff in
there is bright red.–
1990 XJ-S V12 Convertible, Glacier White, 59K miles
San Jose, CA, United States
