My Lucas wiper motor bit the dust before I bought the car. I
disassembled it and found the normal magnets loose, rusted inside,
brushes worn completely out and no protective cover left. I found
and installed an assembly from a 1990 XJS and it works fine on slow
and fast , but not the parking and intermittent function. I
couldn’t find any information on this swap in the archives
specifically. I would like to know if anyone else has done this
and if your results were the same or should my intermittent and
parking functions be working with the newer unit? I like that it
has the bar mechanism instead of the cables.
I noticed that it had wiring going to the washer jets…I haven’t
looked closely to see what that is for…just put it there and
plugged it in…any ideas?–
Bob Clinkenbeard 1987 XJS V12 Coupe
Locust Grove, Georgia, United States
In reply to a message from 87XJScoupe sent Fri 3 Jun 2011:
There was a Jaguar TSB to address this issue. I can email it
to you if you want. I involves a new relay and a wiring
modification to get it to work as originally designed.–
Greg 1985 XJS HE DANA rear
In reply to a message from Greg Edge sent Fri 3 Jun 2011:
Great information Greg and thanks for sending it. Now all I need
is an intermittant wiper relay DAC6053 from a car with the
Electrolux system. Looks like I have to kill one wire and install
that relay and it should work fine.–
If you could send that to me as well, I’d really appreciate it!
Thanks!–
MustangSix
Orlando, FL, United States
Hi Greg,
I know it was some time ago but, could you please also send me this link?
Thanks!
Kind regards,
Bard Thomas
