My top will go down but will not come up…the back windows come up
when I engage the up switch…but the top doesn’t move. Any
suggestions as to the solution to the problem?–
Miss Liz
In reply to a message from Miss Liz sent Sat 3 Nov 2007:
You can switch the pump over to manual and raise the top by hand.
That will at least get you closed up. Then I would start looking at
the relays that control the power top functions.–
Rob Wade
Windsor Ontario, Canada
