[xj] S3 " Euro spec" hubcap
In reply to a message from awg sent Fri 6 Dec 2013:
here is a pic.
I can take a separate on with the items laid out
The SS dress ring is held in place by the wheel nuts, which
are 7/8’’ with rubber washers, there are 5 springs behind.
standard Jag wheel nuts wont work
http://www.jag-lovers.org/snaps/snap_view.php3?id=1386323544&n4=--
Can post a pic if my description is not detailed enough
Tony
Those are pretty rare. I had a stack of one-piece stainless
trims covering the full wheel and held by the same kind of
nut with a flange and spring, but shiny as they were on
view. If you can’t find what you need, your wheels are
probably suited to a set of these which are almost giveaway
in the UK if you ask a few breakers.
Pete–
here is a pic.
1E75339 66 D, 885958 62 FHC,1R27190 70 FHC, 1R28009 70 FHC
Gaithersburg, Maryland, United States
In reply to a message from PeterCrespin sent Fri 6 Dec 2013:
Tony it’s a bit hard to tell from your photo, but the hubcap looks
like the hubcap fitted to the series 1 and 2 cars with chrome turbo
wheels. These hubcaps look the same as the hubcap fitted to the 240
and 340 models, but is smaller in diameter. I don’t know for sure
when turbo wheels were introduced? certainly by 1972, but maybe not
at the start of XJ production.–
Neville S1 XJ12, Megasquirt ECU
Christchurch, New Zealand
In reply to a message from Nev.W sent Sun 8 Dec 2013:
Hi Nev…its different to the S1/2 Chrome wheel hubcap.
‘‘almost’’ same diameter, but flatter
wont quite mount on that wheel, with the 3 pegs that hold
the hubcap
thats what type I have on as a spare atm.
the 3 x S1 or 2 plain steel wheels I have atm take the
larger cap I think, but accomodate my SS dress rings, unlike
the 3 pegged chrome ones…confusing I know
(I also stove a plain steel wheel in on the same day!)
It sure was a mongrel searching the roadside bushes for that
cap…
I will try and put up some better pics–
Tony
The turbo wheels, chrome or painted, came in with the
Series 2 E-type in about 68 and the V12 had them from 71
so I guess with the S2 sedan around the same time? The hub
caps are different to the ones shown for sure.
Lots of people dump the Turbos on E-types to fit spoked.
If all else fails a decent set of turbos should be
obtInable although they are expensive new. I still think
the UK 3.4 S3 style stainless trims might be usable and
would be by far the cheapest solution.
Pete–
