[xj] S3 XJ6 Headlining Color
What is the proper color of the headlining for an 82 xj6? Wre they
all the same color?–
Bruce Kimball
Columbus/NM, United States
Bruce: The 82 car had a different headlining colours for the different
colour interiors, and different than the later cars (after #346688), which
all had “limestone”. If your 82 interior is biscuit, then the headlining
code is AH which is “Fawn”; this is a soft beige colour; the vinyl trim is
black. Any trim shop will have a range of tones which will approximate the
original.
Gregory----- Original Message -----
To: xj@jag-lovers.org
Sent: Monday, February 03, 2003 6:32 PM
Subject: [xj] S3 XJ6 Headlining Color
: What is the proper color of the headlining for an 82 xj6? Wre they
: all the same color?
: Bruce Kimball
Bruce,
If you are going to have a local shop redo your headliner, your best bet is
to find a clean part of the existing material from under an interior trim
piece. Take that to the shop, and visually match it up to the samples they
will have. In my case, I was able to exactly match the color, but the
texture is very slightly different than the original.
Doug Ingram
Victoria BC
1987 Jaguar XJ6 VdP----- Original Message -----
all the same color?
Bruce Kimball
Just to add a comment re ours – my wife has often remarked about the oddly
different colors between the headliner and the rest of the trim/seats, so when
I pull the flopping stuff down, I’ll probably try to match the color to the
seats. Since the 86 is nominally ‘hers’ I’m listening to her on this. :]–
Alex
79xj6L SII (BRG + wires)
86xj6 SIII (Black)
61 Sprite MkII (Red)
Menlo Park, Calif.
original.
Gregory
