just swapped my front wings over with a second hand better pair
the better wings came complete with headlamps, indicators
etc so all I had to do was wire them to the existing harness
indicators were simple
but headlamps are not
same wires as the old headlamps except there is an extra
wire which I do not know where it goes to?
its red, the old headlamp had three wires which the newer
headlamp also has but this red wire is confusing me?
any idead?
if it helps I’ve noticed the new headlamps are ‘‘halogen’’
where as my old ones were the old sealed lamp units–
Gareth McCullough, Northern Ireland , Series 1 Daimler 4.2
The extra wire, Gareth, is almost certainly for the “city light” - the small
5 watt bulb in the lamp (you should be able to see it if you look
carefully). You can leave it disconnected if you want or “piggy back” it to
the power supply.
Gregory,
Victoria, British Columbia, Canada
1966 3.8 Mk 2, Pale Primrose
1992 Series III V12 Vanden Plas, Black Cherry
2002 X-Type, 5 sp. manual, Anthracite
2004 XJ8, Ebony-----Original Message-----
From: owner-xj@jag-lovers.org [mailto:owner-xj@jag-lovers.org] On Behalf Of
G-mac
Sent: October-06-10 8:49 AM
To: xj@jag-lovers.org
Subject: [xj] series 1 HEADLIGHT set-up
any idead?
In reply to a message from Dr. Gregory Andrachuk sent Wed 6 Oct 2010:
Hey guys, is this this the same as the ‘‘dip’’ light? I ran
across a ‘‘dip’’ light circuit while perusing my S1 wiring
diagram, ignoring it until I get the interior back together.
