Hi All, Im wanting to change the front offset on my Jag front ended cobra replica. Need to bring the hubs in just a little, approx 1/4-1/2" to fit a wheel with a slightly different offset. Was hoping I might be able to do this using an alternative off the shelf hub that fits (with the right bearings). Anyone know of anything that may help me achieve what I want? Cheers
Hi Andrew…Im currently building a C type replica…as far as im aware S1/2/3 will give you the same offset…Is it becaus you wheels are catching the calipers…if so you can fit a spacer between hub and disc(3mm)…but on C replica if useing S2/33 calipers they have to be ground down a bit…Steve…PM me for more info if needed
