[xj] Series III Ujoint lube
Any suggestions how to instal (thread) the zerk grease fitting into
the outboard rear drive shaft Ujoint? It is very restricted access
even with the cover slid up the shaft.–
RALPH DEORSAY
In reply to a message from RALPH DEORSAY sent Mon 28 May 2012:
never did this before but I’ve a few ideas that may help: Make sure
the threads match. You might gain more room if the car is jacked up
and the wheel ass. is hanging down, then rotate the tire to the
best position. Use jackstands. Maybe a 1/4’’ socket and extension
will let you get it in. Maybe some electrical tape will hold the
zerk straight? Get it started by hand before you tighen it with a
ratchet.–
Gary '75 sedan (400/400 chevy) +'76 sedan (parts car)
Southern California, United States
In reply to a message from Gary Boehm sent Wed 30 May 2012:
Ralph:
I’ve used a section of rubber tubing to start spark plugs in
difficult areas.
The same technique might just work to get the Zerk started.
Carl–
Carl Hutchins 1983 Jaguar XJ6 with LT1 and 1994 Jeep Grand
Walnut Creek, California, United States
