[xj] Squeeking sound from engine bay
Hi Listers,
I have a very annoying problem. The car drives fine, the temp is
fine, bus I have a high pitched squeeking sound comming from the
engine bay. It is there constantly and it is always the same sound.
It does not relate to engine speed. When trying to locate the sound
with my head in the opeen engine bay, i simply cant find it.
Has anybody experienced the same ?
Best regards
Mikkel===================================================
In reply to a message from Mikkel Pedersb�k Falkenberg sent Mon 13 Aug 2007:
Mikkel
This your SI, right?
In which case it might be worth removing the drive belts and
running the engine to see if the noise goes away.
The noise not varying with engine speed is a bit of a poser, though.–
al mclean '93 XJS 4.0 - '79 SII XJ6 mod - '84 4.2 Daimler
Telford, United Kingdom
Mikkel,
Take a medium length rubber hose and put it to your ear. Move the other end around
the engine bay. When you get close to where the sound is coming from it will be
easier to find.
JoeOn 13 Aug 2007 at 12:27, Mikkel Pedersb�k Falkenberg wrote:
Hi Listers,
Best regards
Mikkel
Hi Listers,
Only as a squealing belt, Mikkel - for whatever reason…
Otherwise you just have to take out the stethoscope for source
identification - as suggested by others…
Frank
xj6 85 Sov Europe (UK/NZ)===================================================
I assume the squeak stops as soon as you stop the engine? if
not it could be a vacuum leak maybe? Not changing pitch with
engine revs is a strange one.–
Keith Turner '79 XJ6 based Aristocat,
Swansea, United Kingdom
Mikkel:
As a long distance WAG, my Jeep had a similar noise, I called it a
whistle. I tried a lot of things and never found it. Then after it
fsiled th smog test, the catalytic converter was changed. No more
whistle and passed smog!!
But, your car may or may not have a cat?
Carl–
with my head in the opeen engine bay, I simply cant find it.
Carl Hutchins
Walnut Creek, California, United States
Mikkel I am having a similar problem and I assume that yours like
mine is hard to find because it only occurs when the car is moving.
Try checking the tightness of the bolts that hold the bonnet
support braces, the top shock absorber mount points and finally the
bonnet locking mechanism. I hope this works for you because it
hasn’t soved my problem. I better get back in the garage to go
squeak hunting. Cheers. Gary–
Gary Hearn
Armidale, Australia
