Hi all I have just lowered my steering rack to sort out a large
leak,i suspect the high pressure hose.Am I right in saying the high
pressure hose comes from the pump direct to the rack and the low
pressure hose returns to the pump via the oil cooler? This is on a
series3 DD6.Also there is a large washer between the steering
universal joint and the rack pinion which is loose and appears to
do nothing what is its purpose? Can anyone help? dennis–
denchan 1990 daimler double six
In reply to a message from denchan sent Fri 22 Jul 2011:
Further to my last post the high pressure pipe seems ok so I have
removed rack and will get a seal kit to cure the problem I hope Has
anyone fitted new seals to a rack, was it successful? and any
problems doing it. Is it the pinion seal thats most suspect?
any help will be appreciated Dennis–
I once put new seals in the power rack in one of my E-types.
It is a PITA to take the thing apart and put change them. Be
very meticulous when it comes to the tower; with its valves.
I don’t know if you have a place to get a rebuilt unit, but
I opted for a professionally rebuilt unit for my XJ. It is
too much hassle to r+r the unit, when I am not sure I could
tell if the bushings were worn. Changing the seals is only
one part of the equation. You will also need to know if the
inner rack bushings are worn. As for the rack mount
bushings, I went with black urethane. They are firmer than
the ‘soft’ urethane. You don’t really pick up any
significant road vibration, and the rack has less lateral
movement when turning side to side.–
Tom Hishon, 69 E-type 2+2, 69 E-type OTS, 85 XJ6, '03 X-type
Wasilla, Alaska, United States
In reply to a message from kassaq sent Fri 22 Jul 2011:
Thanks Tom I would like a exchange unit but funds are rather low at
the moment so im forced to try the kit Ill remember what you
advised though and be as careful as I can Dennis–
Hi Dennis, I too have tried to change seals myself and not only was
it a pain but also a waste of time as the system leaked again
immediately afterwards.
My funds are always low, so one option I discovered that you might
like to consider is to take the rack and seals to a local steering
repair centre and ask them to fit them for you.
I did that and they sorted my problem, in a fraction of the time it
took me to make it worse, and charged me less than a quarter of the
cost of buying and shipping a refurbished unit.
Franksy–
In reply to a message from franksy sent Fri 22 Jul 2011:
Thanks Franksy That did wonders for my confidence to do the job I
think I might have to search around to find a steering shop. I dont
want to buy two lots of seals Dennis–
