Alex, thanks for the reply.
I am still stuck on fixing this problem. At the present, I found that the buzzer goes on when the interior light switched is depressed only if the front two courtesy door lights are connected. Right now, I disconnected them so I could use the main interior light without the annoying buzz. Any other ideas??
Also, if I remove the fuse to the interior lights and have the front door courtesy lights connected with the ignition switch in the number 3 position, the buzzer sounds like its winding up like theres too much power to it.
Dominic Cutuly
85 VDP currently in VA===================================================
