Have a stumbling problem on the 78 after driving a
while.
Its warmed up every time it does that.
Its hesitating before picking up speed, it might
do this about 3 times, then its OK.
‘Warmed up’ means temp gauge showing normal engine temps, Walter - or
what…? ‘…after driving a while’ - the engine may still be in the warm-up
phase…
Does it misfire, or is the throttle response just slow - when this happens?
And it happens at cruising speed, or if the throttle has briefly been to
idle/low?
As you have readjusted the throttle gap, with no effect on the stumble; this
should also increase the idle rpms. But as it had no effect on the stumble;
reset gap to specs…
If you have the O2 sensor; disconnect sensor and test drive. Somewhat
convoluted; as the O2 sensor gets hot and the Lambda start playing, it may
cause a change in fuelling that the engine does not like at that engine
temp. As the engine reaches proper temp - it is satisfied with the mixture,
and responds normally. The point being that with any suspected fuel
problems, the O2 sensor should be routinely disconnected to ensure the
Lambda is not involved. The engine should run perfectly with the O2 sensor
disconnected - or basic settings are incorrect…
I assume you had the problem before you changed the items mentioned - and
the changes made no difference? Paul’s ide about the spark plug gaps should
be pursued - the old ones may have a wrong gap as well…?
Watching the tacho when the stumble occurs; does the readings fluctuate
outside the engine rpms…? Indicating an ignition issue…
Frank
xj6 85 Sov Europe (UK/NZ)
Adjusted mixture screw to lean, with no effect.
Adjusted mixture screw to richer, with no effect.
Adjusted .002’’ throttle plate to .003’’ with no effect.
I have a new fuel pump.
Have new fuel filters.
New spark plugs.
New ignition coil.
Replaced ‘‘O’’ ring at mixture adj. screw.
I had this problem for some time now.
Any advise from anybody, what I’m overlooking?-----Original Message-----
Sent: Wednesday, November 02, 2016 9:38 AM
To: xj@jag-lovers.org
Subject: [xj] Stumbling on takeoff, 1978 XJ6 ser.2
