A little while ago several listers kindly helped with advice and
comments about temperature senders and I promised to let the list
know about the results of some calibration tests.
In the hope that some may find this of use, here are the figures
for an old sender and a brand new one. I’ve also checked what
resistances are required to produce indications on the SII temp
gauge. This has no figures, just the word ‘normal’ on the gauge.
The senders are identical in appearance, the new one is labelled
DAC2583
All temperatures are in degrees C and were measured with the
thermocouple of a digital multi meter while the resistance in ohms
were obtained from a second meter connected across the sensor which
was immersed in a pan of water. The resistance readings were
obtained by substituting a potentiometer for the temp sender,
adjusting it to give a steady reading on the gauge and then
measuring the resistance.
Old sensor New Sensor
55� 270ohms 255ohms
60� 230ohms 210ohms
65� 195 177
70� 163 150
75� 145 128
80� 129 110
85� 111 92
90� 90 73
95� 78 62
100� 64 55
Gauge
n o r m a l
93 83 73 63 54 45 ohms
(If your browser doesn’t print the columns in a sensible format and
you are interested, email me off list and I’ll send a excel
spreadsheet and image of the dial)
From these figures it seems that a reading in the middle of the
word ‘normal’ could indicate a temp anywhere bewteen 90 and 98 C.
This strikes me as a little high but I’d be interested to hear what
others think.–
al mclean '93 XJS '79 XJ6
Telford, United Kingdom
