Thanks Scott, it worked just that way and I discovered, lo and behold, the
wiring for the prior analog clock still in the harness there. Boy, they sure
did use up inventory. I may dump the TC and put a real SII clock in, because
I hate having to turn on an ignition just to see what time it is when I’m
working on a car. The wire that’s supposed to sustain the radio’s memory was
apparently connected to the TC’s similar one and opened somewhere, so I just
bypassed it with a new wire from the radio fuse in the side panel. That fuse,
it turned out, was also playing the old Lucas rotating-fuse-cap game, so was
intermittent. I refused to go to bed before it was all fixed. We’ll be down
one of these days to pick up the stuff and check your progress on Sir Lump!–
Alex
79xj6L SII (BRG + wires)
86xj6 SIII (Black)
61 Sprite MkII (Red)
Menlo Park, Calif.
Scott Fraser wrote:
At 09:38 PM 6/5/02 -0700, Cannara wrote:
I need to figure out why a red wire to battery power in our 86, that appears
in the radio connector, seems to have gone open and affected the Trip Comp.
too. How does one pull out the TC?Alex,
I have one in my hands here and each side has a set of spring steel tabs
holding it in place. It looks like a well placed pull will pop it right
out. Careful with the wood.I still have your belts and rear panel keeping warm here.
Scott
