My trip computer works sometimes.but don’t work when
pushing buttons. Is this a common problem. Is this unit
connected to main ECU?
Assuming you have display, Daniel - the unit has power, and the fault
depends on what functions are missing…
The computer has two power feeds; constant, ‘standby’, power (car brown,
computer purple) and green, power with ign ‘on’. Actually, there is also
a third; red/blue to dim the display with lights on…
‘Time’ is run by the internal clock - pushed, it initially shows driving
time, then switch to normal clock function. "avspd’ is computed using the
clock and the speed transducer on the gearbox. "dist’ is computed from the
transducer directly. ‘ave’ is computed from transducer and ECU for average
fuel consumption. ‘inst’ uses the transducer and the ECU to compute instant
fuel consumption. And ‘fuel’ uses ECU give total fuel consumed…so…?
All data, except clock and some transducer data, goes through an interface
unit…
Adventures souls have accessed the computers internals for repairs - which
requires some nous, referred
Frank
xj6 85 Sov Europe (UK/NZ) to in the Archives…
Is there a trick to fix connector
shorts, ETc any input anyone cheers-----Original Message-----
Sent: Thursday, January 01, 2015 2:23 PM
To: xj@jag-lovers.org
Subject: [xj] Trip computer
