[xj] V12 temperature sending unit readings
Data, data, I can’t make bricks without
straw (or something similar said by
Sherlock Holmes).
Robert Egerton and I have been exchanging
notes regarding sending unit readings
at various temperatures – I because of
concern that the gauge reads high, Bob
because his reads low.
This may be a way to translate your
gauge reading into centigrade scale.
Before going further, I would like to
collect more data.
Would you please check the reading from
spade to sensor body (with single wire
disconnected) with your V12 at
operating temperature? Using the ohm
scale on my digital multi-meter and
crude experimental apparatus, I obtained
the following reading of which I am
fairly confident.
C Ohms
135 29
130 31
125 34
120 38
115 43
110 49
109 50
108 52
107 53
106 54
105 55
104 57
103 59
102 61
101 62
100 64
99 65
98 68
97 70
96 71
95 73
94 75
93 77
92 79
91 81
90 83.5
89 87
88 90
87 92
86 95
85 97
84 100
83 103
82 106
81 109
80 112
75 131
My XJ12 with 88C thermostats
appeared to be running at
about 94C and I know of at
least one other that is
similar. If anyone is
willing to attempt replication,
I would be happy to describe
the equipment and methodology
used. Please reply directly.
Thank you.
Steve
