I’ve just noticed I have a small leak from what looks to be
the bottom edge of the water pump, when the engine is
running small droplets of coolant get blown up. I plan on
taking a closer look at it this weekend, is this likely to
be just a seal/gasket failure or would it be time to replace
the pump?
the pump?
I had the exact same problem …replace the pump.----- Original Message -----
To: xj@jag-lovers.org
Sent: Friday, February 23, 2001 3:20 PM
Subject: [xj] Water Pump?
the pump?
Hi there
I’ve currently got the same scenario with my SII xj6L- Make sure that it is
the pump by getting underneatth with a mirror and a light as there are many
hoses around there that can leak small amounts and mimmick a water pump- if
in fact it is the water pump then best to replace with a reconditoned pump
(Here in Australia a new aftermarket is available from Repco for ~ $AUS500 ,
and a fully reconditoned with new gaskets etc for $120- Reconditoned in my
opinon).
Best of luck
Peter_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
