In reply to a message from wosmo sent Thu 9 Oct 2008:
War stories? I’ve got one.
Many years I was driving around Colorado in a Mercury comet-
you know, the one with the might 202 straight six engine.
The carburetor was a little tricky on a cold start, so I
took to using a screwdriver to hold the choke plate open to
start it. One morning after sleeping in the car in the
mountains, when I went to start the engine, the screwdriver
slid down the barrel of the carb when it started, and held
the throttle plate wide open!
The engine gunned, and then clanked to a stop abruptly.
After a bit of work, I found that a piston had been ripped
off the crankshaft bearing- and the rod was keeping the
crankshaft from turning.
So, having a lot of time, and my car tools with me, and not
wanting to pay for a tow, I opened up the top end of the
engine. I applied a dab of epoxy to the top of the
stationary piston, and, with a nail glued to the piston
head, pulled up the piston and removed it from the block.
Then, I put the top end back together again.
The engine started up, but ran very rough and I couldn’t go
over ten miles an hour as I drove back into Fort Collins-
about a twenty mile drive.
Then, I stayed a hostel, ordered the piston for about 25
dollars, gaskets for about ten, and in a week had the engine
put back together and on my merry way.–
BudFox
