[xj] Which valve in Wheel well?
Don’t hav my notes nor links for the venting fix on the valve in the RF
wheel well — Which one takes the 1/8th drill bit? the one with 2
connectors, or the one with the 3 (one off to side)
Thanks
Ken
1987 Series III VdP - the “Roadrunner”
169,000 mile Daily Driver
Space… Pace… Grace… With a shiny new exterior
http://weather.azkiwis.net - for the Sonoran Desert Weather===================================================
In reply to a message from Ken Davis sent Thu 25 Mar 2010:
the one with two hoses connected to it, and which is mounted BEFORE
the charcoal canister; Also, one hose has a larger diameter than
the other, so you cannot connect the valve incorrectly.
if you look at the front, passenger side wheel, the valve is
mounted at 12:00 o’clock behind the tire, above the upper wishbone.
Zurdo–
Thanks
Ken
1987 Series III VdP - the ‘‘Roadrunner’’
1965 3.8 ‘S’ 1984 XJ-6
Florida, United States
