Cannara <@Cannara>
Bob, I agree, having taken JohnT’s 70-spoke Daytons over. They are in line
and seem to be fine, with these two caveats: 1) the balancer must have, and
know how to insert, the test hub cone properly; and 2) the spokes need to be
checked for uniform tightness. I’d ask Dayton for a spec on that. If you do,
let us know what they say the spokes should sound like when plucked! On ours
I notice that certain sharp pavement bumps can raise an audible clickety from
the spokes, so I may well need to do some tightening. However, like Jim, I
sometimes drive hard and have tested them that way on very sharp turns, with
no problems. They do make the SII look more true to an earlier era. One
other thing – carefully oil each spoke adjuster and the spoke fitting as seen
from inside the hub. This will make them easier to adjust later and avoid
some rusting, despite making the wheels a bit messier for a while afterward.
By the way, I kept the original “turbo” chromed wheels, just in case. {:o]
Alex
79xj6L SII
Menlo Park, Calif.
MillTech wrote:>
MillTech MillTech@Pacbell.net
Peddlarbob@aol.com wrote:
Hi Gregory. I am not the sort to disregard free advise and your comments
have given me reason to doubt my decision to install these wire wheels on a
car that has just under gone a costly restoration. However I did contact
Dayton Wheels in Ohio to find out more about these wheels that I have. They
told me this particular series of rims where produced specifically for use on
Jaguars and are suitable and safe to install them on my XJ series Jaguar.
The type that I have are simulated knock on’s with a simulated knock on nut
(cap). They actually bolt directly to the hub. A phone call too Jaguar’s
Coventry headquarters’ got the answer to this same question “We do not
recommend any rim to be installed on our cars other than what we manufacture
for safety reasons”. Gregory, do you have any personal knowledge or know any
one that has used these rims and experienced problems. I thought the
questions in my mind about what to do with the engine was going to be the
hard one this has turned out to be twice as hard. If I decide not to use
these rims do I just eat the cost or do I sell them and pass the problem on
to someone else, tough decision. Regards Bob.===================================================
To remove yourself from this list, go to Jag-lovers Forums - Jag-loversBob,
Keep the wheels. Use them. Enjoy them. I have had a set of Daytons on
the SIII for 5 years. It came with them. I drive the car very hard. I
use Eagle One cleaner. Works great. The safety issue with these wheels
is in my opinion mostly bafflegab. Dayton did upgrade the number of
spokes to 70 for the heavier cars. There is no way, in our current
litigious times, that Dayton would continue making them if they were
dangerous.Regarding phone calls to Jaguar, remember a) the people that you talk to
are employed to sell Jaguars and Jaguar parts only, and they, more than
likely, have never even seen a set of Dayton wires up close.Secondly, Gregory, I think you need to ease up on chastising newbies
regarding ‘purity’ of the car and it’s fittings. As I recall when you
get a car, you change the purity of the trunk by installing an extra
light. You prefer the 7 inch headlights to the smaller ones. It appears
that a double standard exists. These are changes you make that you feel
are acceptable. Other purists may feel that they destroy the car. I
know a few ‘concours’ types here in San Diego (from other marques) and
they would be horrified at the idea of screwing a light fixture from an
xjs into something like the v12 you just bought.Jim Downes
