Cheers Paul
You were spot on
Tried a different hazard switch and it all worked as it should
njk1963,
Thank you for posting your results and letting us know that a replacement Hazard Switch fixed your problem. After owning and working on several Series III saloons over the past 19 years sometimes I get lucky.
I hope that your post helps others who have this problem and search the archives for answers.
The 9-pin version was the later one, Ick - nominally fitted to the S3…
This was likely more ‘failsafe’ than the 8-pin one - less prone to internal failures giving symptoms you had. Changing the switch, as you did, was right and proper - well done…
Frank
xj6 85 Sov Europe (UK/NZ)
