The fuel pump relay must have a Bosch part number stamp on the metal case.
It also has the schematic.
On the SIII, and must be the same case on the SII, it has no extra diodes so a ordinary 30A SPDT relay will do the job fine.
I can surely get the numbers stamped on it, but since I’m not sure it’s the original one, I wouldn*t bet on it.
That’s why I’d like someone with the same car (v12 coupé or sedan) to give me the exact Lucas part number.
No doubt for the cold start relay… but still a question about the fuel pump’s…
Just had a look at my diagrams and there is conflicting info…
This is from Roger Bywater AJ6 Engineering, it shows a simple SPST relay:
This is from the 1987 XJ-S Jaguar manual, it shows a “dual 87” SPDT relay.
From what I understand the second 87 connection powers the 45sec delay timer and the heating elements of the O² sensors.
These diagrams are for XJS from the 80s.
Mine is a XJC from the 70s.
No chance the relays are the same.
Even less chance that I replace the original by a different one.
That.s why I need the original part number
Oh, there’s a decent chance that at least of them are the same. Relay technology of the period didn’t change a lot…and Jaguar itself was never in a rush to change anything.
In many cases the old original part numbers have been substituted…or the original part discontinued…but some Googling and cross-referencing will usually reveal a present day equivalent
I wasn’t referring to any specific diagram or circuit. I was merely offering up a little warning that some relays are dual 87. Just something to watch for with ‘ordinary’ and ‘simple’ relay replacements, that’s all
If it’s the same as the photo bellow, I believe it’s the LUCAS 33213 - 6RA
If you are interested, I can look in my pile of spares and see if I have a original one.
That’s very kind of you.
It looks the same and that’s the problem: I also have a lot of parts here that look exactly the same, have exactly the same body, but not the same reference and use.
This one on the pic is a 6RA with 4 pins.
On the xj12 s2, it should be used as a main relay and surely won’t work for cold start which is a 25RA, 5pins, under the reference 33353A.
Question remains for the fuel pump’s.
According to the original diagrams, it should be the same as for cold start… but no strong confirmation yet.
