Hi guys,
I need to get to the ABS module… thought it was in the boot somewhere near ECU unit but it is not… any idea where it is hidden?
Thank you for help,
Cene
Hi guys,
Thank you for help,
Cene
I think it’s behind the rear seat, right side.
Rob
Oops, or, it’s in the boot, right front, where the engine ECU is.
Rob
Rob,
not there. I thought that, too. But it is not there, checked…
Cene
Not sure if this helps…
DD
Thanks, Doug.
I guess the position depended on the day of the production and the mood of the workers in Jag factory…
In my Jag the control unit (module) is not located in the boot, near ECU as probably should be by the official diagram…
Chris from KWE Jaguar in UK wrote me that the control unit is in the cabin near the blower fan - on the passenger side… will try to find it there.
Cheers, Cene
Guys,
ABS module found…on the driver side behind the panel…strange. It seems to be Bosch module with number 0 265 105 032.
Jaguar part was named ”electronic control module” with number DBC5980.
I need pinout scheme of that module. Any idea where can I get one? Tried to find in on the net but no luck…
Cheers,
Cene
