Needs help on decode a trouble code ( FUSE FAILURE 2 )and where can
I locate the problem?–
411sd
In reply to a message from 411sd sent Sat 22 Nov 2003:
That code indicates that you have a blown fuse in the fuse box at
the base of the left hand ‘A’ pillar. The ‘lightning bolt’ icon on
the dash should also be illuminated.
Check which system on the car is inoperative and then locate the
fuse from the circuit description on the inside of the fuse box
cover - or pull all the fuses one-by-one and check them
individually.–
Bryan N ('91 Sovereign 4.0 L)
Cambridge, United Kingdom
The Circuit 2 fuse failure light indicates a blown fuse in the panel in the
left side foot well.
Clark
'88 XJ40
'67 420
'67 S-Type----- Original Message -----
To: xj40@jag-lovers.org
Sent: Saturday, November 22, 2003 6:18 AM
Subject: [xj40] 91’vandenplas need trouble code infor.
