Any reason that my 89 XJ40 A/C seems to run “not as cool” when idling?
This seems to be more prevalent after just starting the car and running for
just a few minutes.
Belts? freon? Other?
Thanks in advance,
Mike
just a few minutes.
Thanks in advance,
Mike
To: modern@_jag-lovers.org
Message-ID: 852564C6.007805BC.00@davros.teir.com
Date: Mon, 30 Jun 1997 17:53:30 -0400
Subject: XJ40 - AC
Sender: owner-modern@jag-lovers.org
just a few minutes.
Thanks in advance,
Mike
Mike, this is normal for all cars…every car I have owned does this.
Its due to the compressor turning slower,and less air flow thru the
condensor coil.
Car ac is always a compromise as the input power varies(rpm).
If the compressor was a monster and cooled like crazy at idle,
then they would have to come up with a way to dump all the
pressure when you had the engine turning at 3000-6000 rpm.
The ideal way would be to have a comp. that turns at a steady rpm.
Brett
