Hello all. Interesting reading from chaps with xj40 starting problems.
So…my 1991 xj40 3.2 litre starts okish cold but once hot doesnt. Like the other chaps when hot the eng spins over and over and no start,switch off and restart, the eng fires immediately.
Put a pressure guage on and pressure reads 40 lbs, but drops very quickly.
So as i had a new fuel pump fitted may 2023, which didnt cure the problem, what do you think?
Is there a non original non return valve that can be fitted under bonnett to solve the problem?
Instead of replacing the fuel pump.
I had to try multiple times to start the engine until it was suggested to cycle the ignition key a few time to prime the fuel rail. Once the one way valve was in it cured the hard start, however the previous number of attempts to fire the engine resulted in the Bosch starter grenading the reduction gears, thats when I found out that the 2.9 through to the 4.0 all used an identical starter according to the Bosch website.
Hi Robin.
Interesting about the fitting of non return valve. Was yours an iiside tank pump type, and if so, whete did you put the valve under bonnet?
Also, where did you get your valve from please, and have you a picture,?
What do you mean when u say about the starter, " grenading reduction gears" problem?
Rgds
Hi again Robin.
Just re reading your info about non return valve sited in the return fuel line.
But does that help the poor starting as would thought the non return pipe should be in the feed pipe,?
Be interested to hear your views please.
Good morning.
Can anyone tell me the thread size and type where the brass fitting is where inlet fuel line joins the fuel rail on a 1991 xj40 3.2 litre under bonnet, just after the diaghram?
Thank you
Neil
