When you find it, be sure to post it because I have the same problem
and can find NOTHING loose. Mine is a bit more of a clunk, but it
happens at the same time. We have 5 speed bumps leading away from the
house and on 0 to 5 of them, it seems to varry, there is a clunk.–
Jim Isbell
“If you are not living on the edge, well then,
you are just taking up too much space.”
In reply to a message from Jim Isbell, W5JAI sent Thu 8 May 2008:
Check out your front passenger side upper shock bushing. May
be deteriorating?
Good luck!–
In reply to a message from FinFan sent Fri 9 May 2008:
In my case it turned out to be a bad sway bar link on the
right front: CAC9827
It gave a loud ‘‘boing’’ noise when the car went over a stiff
bump or leaned to the right during a hard left turn. Shop
charged me US$83 for the part plus $35 to install it.–
84 XJS, 89 XJ40
Santa Barbara, CA, United States
