has anyone eliminated the abs system on the 88xj40? can you
use an older system from an xj6? I also would like to do
the same on our 89 xj-s
frec38–
lisc 88xj40
In reply to a message from frec38 sent Tue 26 Feb 2008:
Are you asking to actually remove the entire ABS system, or
just the hydraulic booster system?
There’s been a well documented process to retrofit the
system to use a vacuum brake booster.
Eliminating the entire ABS system would be much more
involved, but with a good front/rear disk master cylinder,
brake proportioning valve, a bunch of hydraulic tubing and
fittings, would not be that difficult a job.–
You can ‘eliminate’ the ABS simply by unplugging it, either at the
control box itself – mounted behind the carpet on the left side of
the trunk – or by pulling the relay. With power off to the unit,
it ceases functioning.–
As you headed your query ‘‘Brakes’’ I will assume you wish to remove
the the booster and go to vacume, you will still have your ABS
system. Contact me and I will give you the details regarding the
change which takes about 4 hours and $250.00 us. John.–
John. Walsh. Purrrrr 89 vdp
bowmanville ontario, Canada
In reply to a message from h s law sent Tue 26 Feb 2008:
‘‘You can ‘eliminate’ the ABS simply by unplugging it, either
at the
side of
unit,
it ceases functioning.’’
Does this get any warning lights on the dashboard? Pulling ABS
fuse will light up circuit failure symbol.–
Snowcat, -89 XJ40
